For the love of god please help me
Discussion in 'The Projects Forum' started by Smitty3896, Jan 8, 2014.
Thread Status:
Not open for further replies.
  1. Smitty3896
    Jan 8, 2014
    I was looking for a "please help me, I've never messed with electronics before and have zero clue on what I'm doing" section, but this was the closest I could find.
    I'm working on a new circuit for my car. I'm hardwiring my gps and radar detector, as well as my fog and racing lights. I bought a project enclose from radio shack and went for it. I drive a mini, so my battery is in the back. I have 10guage leads going up to the front. The positive goes into a 35 amp toggle switch. Then to a distribution block to the four switches. The negative is the same, just skipping the switch. When I have one of those jumpers that has a battery so you can jump you car without another car. On my work bench I hook the system up to it, and using my multimeter I get 12.71v from all the outputs. Next, I hooked up my fog lights, gps, and radar, they all worked perfectly without any issues.
    This evening I went to install the box. Before I connected anything I measure the main power leads. I got 12.41, which is lower than the jumper, but still above the 12 volts everything needs to work. So after installing it and hooking it up, my radar comes on fine, yet the navigation and lights won't. I have a 1 1/2a inline fuse for the radar, and a 15 for the lights. For the gps I just bought an auxiliary 12v outlet, then hooked the normal cigarette lighter power cord into, and secured it with heats shrink.
    I really don't understand it, I haven't messed with electronics like this before, and I can't figure out why everything works on the bench, then I carry it 5 feet to the car, and nothing. Thank you soo much for the help in advance
  2. ilnar
    May 8, 2012
    16
    first of all, draw a schematic. download orcad and do it.put the picture here. or get a pencil and a paper and draw your connection diagram; put a picture here. from your text i don't get what goes where.(in short you have to provide the map of your connections). after that, we will have to go step by step towards the root of the problem.
    this project from radio shack, does it have the datasheet? or schematic file with it?
    " For the love of god please help me" really almost put tears in my eyes :D and if you will look into a Tags section below, webpage generated 2 tags out of your thread name: god, and love :))))))))))))))) not "electric problem" or "lost in wiring" . just god, love :) so mostly people who search for god and love will find you :) not engineers :)
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    Unfortunately, projects that modify cars are not allowed here so this thread will be closed soon.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
