For my country
Discussion in 'General Electronics Chat' started by ko lay shine, May 28, 2015.
  1. ko lay shine
    May 28, 2015
    Hello Ladies and Gentlemen
    I am Shine. I am new here.
    I want to know something that will change my country.
    Please kindly help me.
    We have big fish ponds in my country.
    People pump huge amounts of water into the pond from the water stream which is just beside the pond.
    The regular system with generators consumes lots of fuel.
    So, we need a special DC pump which can pump huge amount of water but through a short distance.
    Is there any system that suits our need. We have millions of people who spends billions of money for everyday fuel.
    Help!!!
  2. PackratKing
    Jul 13, 2008
    850
    216
    Greetings... Is there any difference in elevation between pond and stream... Perhaps a siphon would be adequate ?
  3. ko lay shine
    May 28, 2015
    Yes there is elevation . But the pond's water level is lower than the stream's water level.
    I doubt DC pumps cannot pump that much water. ???
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    if the pond is lower than the strean, a syphon would work, and consume no fuel.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    If the pond is lower than the stream, I do not see how it is not already part of the stream.
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    What country are you in?
    Can you post a map of the area or a link?
    How much water per day do you want to move?
    ak
  7. sirch2
    Jan 21, 2013
    1,008
    351
    Why doesn't the pond dry out if you are pumping water out of it?
    Elevating a certain amount of water by a certain height has a fixed energy requirement, there is no way round this. The only thing you can work on is the efficiency of your system and the more stages you go through the less efficient the system. Just get a petrol/diesel pump and use that. Using a generator and AC/DC converter will be less efficient.
    ko lay shine likes this.
  8. shortbus
    Sep 30, 2009
    4,095
    1,681
  9. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Hopefully you are not involved in a project such as this producing Basa and Catfish.
    Max.
    ko lay shine and mattbullet like this.
  10. mcgyvr
    Oct 15, 2009
    4,789
    975
    As already stated..
    If the pond is lower than the stream then you simply need to use a siphon (no fuel/pumps needed at all)
    May need a pump to get the siphon started but after that it can be taken offline
    http://en.wikipedia.org/wiki/Siphon
    Thanks Bernoulli..
    Siphon.. I love it..keeping my fish tank/sump system running quietly for years..
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    Why a siphon? Why not just a ditch? Let the water do it's thing...
  12. wayneh
    Sep 9, 2010
    12,382
    3,238
    Like this.
    ko lay shine and strantor like this.
  13. ian field
    Oct 27, 2012
    4,447
    791
    If the stream has a decent flow rate, you can use an Archimedes screw powered by a paddle wheel on the end that dips into the stream.
  14. WBahn
    Mar 31, 2012
    18,087
    4,917
    Are you sure this is what you meant?
  15. wayneh
    Sep 9, 2010
    12,382
    3,238
    I assume people wouldn't be using pumps if they didn't have to.
    But I don't see the connection to needing a "special DC pump". What's needed is a more efficient pump that runs directly off the fueled engine, eliminating the generator.
    I'm skeptical that there is a wide demand for this. It's a pretty obvious solution. There's probably a good reason things are the way they are.
  16. ko lay shine
    May 28, 2015
    Okay Is there such pump? What about fuel consumption?Thabks
    Yes! A siphon would be okay but the water leve
    Yes! A siphon would be okay but the water level is not always the same. That is why we need a pump.
    That's what I am thinking about. But I have to study about more about ram pump. Thanks
    My country is Myanmar.
  17. Externet
    Nov 29, 2005
    776
    57
    I worked 10 years designing and running ~4000 acres of shrimp farms overseas... The water streams are very unlikely at higher level than the ponds. Description has to be a mental fart. I used two 30,000 gallons per minute 30 inch diameter pumps with 671 DetroitDiesel engines at every farm, for 5~10 feet head.
    The only way to pump some little flow with no fuel expenses is by using the stream speed (likely too slow to be useable) to move a pumping paddle wheel; or a massive solar panels investment.
