Fod2711a
Discussion in 'The Projects Forum' started by anoman38, Apr 8, 2012.
  1. anoman38
    Dec 28, 2011
    10
    I'm currently using FOD2711A optocoupler as an isolation between the PWM generator and the rest of the circuit. I connected the optocoupler as shown bellow. My problem is that the output voltage is not the normal logic signal. At frequency less than 5KHZ it works nice since the output voltage is a logic signal with 10V peak but in the case of high frequency the Vout looks like a capacitor charging voltage( goes up with delay). Attached to you Can my circuit. you please help me.
  2. rfredel
    Jan 23, 2011
    25
    I think, the Load-resistor of the transistor is to high, Look for the datasheet at page 10. There you see that the voltage gain quickly goes down. It's better to use a resistant with 100 or 500 Ohms.
    Regards
    Rainer
    PS: Sorry, if my English is not so good
  3. anoman38
    Dec 28, 2011
    10
    I have tried as you mentioned but problem still unsolved.
  4. praondevou
    Jul 9, 2011
    2,936
    489
    1. What exactly did you try? What resistor value?
    2. You are driving the LED with a current near its maximum rating , decrease it to 10mA.
    3. Then consider for the collector resistor calculation a CTR of 100%.
    4. What is connected to the output (apart from the resistor)? Maybe some capacitive load?
    5. At what frequency do you want to drive the opto?
  5. anoman38
    Dec 28, 2011
    10
    Dear praondevou
    The input resistor is selected to be 350ohm, so the LED current is 10mA. The CTR is considered 100%. the collector resistor is 700ohm. I'm checking the output voltage of the optocoupler without connecting the output pin to any load. Just connect the oscope between the pins 2 and 3. I couldn't find a better output signal. The switching frequency is 40KHZ.
