FM TX and RX design need help
ericyeoh
Joined Aug 2, 2009
58
Hi all,
I'm doing a project FM TX and RX design without using any help of IC.
The frequency band is choosen to in 40.xx Mhz for the project. This is the ISM band.
Please purpose if you have any.
TQ
bertus
Joined Apr 5, 2008
22,278
Did you already have a look in the RF related links thread?
Basicaly the change to an other frequency is changing the tuned circuit of the transmitter and reciever.
For better stability take a look at some transmitters using an X-tal oscillator.
Bertus
ericyeoh
Joined Aug 2, 2009
58
Tq for quick reply bertus, i was not sure about changing the "inductance" tank circuit could actually achieve the desire frequency.
Thx for your hint, i will focus into that area.
radiohead
Joined May 28, 2009
514
You can build a transmitter using a crystal to lock your frequency. Google is your friend. There are hundreds of thousands of hits for crystal transmitters. It is up to you to choose one depending on the complexity of the circuit you want to build.
ericyeoh
Joined Aug 2, 2009
58
Hi all,
I got updated from my supervisor, he requests me to use VCO to build the transmitter and fix the output frequency to 40.xMhz.
Can any 1 share the concept or idea?
i'm still fresh
ericyeoh
Joined Aug 2, 2009
58
Hi bertus,
Yes, PLL can be included. Anyway, how could i fix the FM TX center frequency to 40.68 Mhz using VCO + PLL. Sounds like the TX getting complex.
ericyeoh
Joined Aug 2, 2009
58
Hi all,
I would like to make clear on something. I just updated from my supervisor, he has told me to try achieved the modulation index, B ~ 5.0 (if possible).
My project is basically design a FM transceiver.
Input : microphone (human voice)
Output (TX) : able to produce the (human speech)
Design requirement
TX :1.Frequency must be ISM band ~ 40.6Mhz.
2.The design must stick with VCO + PLL.
3.Intergrated circuit is restricted for designing the VCO.
RX : The design could use IC to implement and must be able to receive the correct signal.
ericyeoh
Joined Aug 2, 2009
58
Hai all,
How can i control the frequency deviation?
What is the max modulating frequency if the input is human voice to micophone?
