FM/TV transmitter
Discussion in 'General Electronics Chat' started by Chritoph8r, May 17, 2010.
  1. Chritoph8r
    Jan 19, 2010
    33
    Hi I need high watts FM transmitter Diagram and simple tv transmitter. I created already fm transmitter but very low watts. and tv transmitter but the output is not clear.
  2. oidium45
    Apr 24, 2010
    130
    8
  3. Chritoph8r
    Jan 19, 2010
    33
    ^ thanks oidium45 the diagram you given to me have a low range compare to my created FM transmitter.
    my Math correct me if I'm wrong :)
    FM transmitter for 5w = 1000 meter, 3 km, 1.5 miles
    I want to create at least 100watts or even more :) pll or vcu control or others or even analog circuit.
    thanks
  4. Chritoph8r
    Jan 19, 2010
    33
    or just 50 watts :)
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    What part of the world are you?
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Why do you want so much power.
    A good antenna will help more.
    I have a 3.5 watt transmitter that reached upto 30 km.
    Keep the regulations of your country in line with what you are doing.
    Bertus
  7. retched
    Dec 5, 2009
    5,201
    313
    Are you trying to make a television or radio station?
    Have you been watching 'Pump Up The Volume" too much lately?
    What area of the world are you in? Is there mountains or high points?
    Have you ever broadcasted anything before? Even used a CB?
  8. Chritoph8r
    Jan 19, 2010
    33
    I'm in the Philippines, yes I'm thinking of making a radio station :)
    my friend (former classmate) buy a 200 watts FM transmitter in local store here in the Philippines but he had no knowledge of electronics. now he have his own FM radio station with a license on NTC (National Telecommunication Commission) My advantage to him, I have a knowledge in electronics and my place is building style 5th floor the antenna receptor it's not my problem.
    retched Are you trying to make a television or radio station?
    I'm in the City too many high building structure.
  9. retched
    Dec 5, 2009
    5,201
    313
  10. oidium45
    Apr 24, 2010
    130
    8
    My best advice would be to find a commercial transmitter that fits your needs and hunt down a circuit schematic for that particular transmitter. You can then either use it as a base for designing a transmitter to fit your needs, or just build that particular transmitter yourself (or a similar one) if you can acquire parts cheaper than actually buying the unit.
    Otherwise, Good luck hunting!
