fm receiver
Discussion in 'The Projects Forum' started by real_assassin85, Jul 18, 2007.
  1. real_assassin85
    Jul 18, 2007
    8
    :) hello i'm a student and having a problem on how to build a fm receiver..can anybody give me any kind of idea,advise and solution because this problem related to my final year project..
    i'm also need the instruction and component list on how to build this project because i will try to build on my own..i really need help from you guys..thank you..
  2. real_assassin85
    Jul 18, 2007
    8
    i really need help..
  3. JoeJester
    Apr 26, 2005
    3,403
    1,230
  4. real_assassin85
    Jul 18, 2007
    8
    thx for helping..but that page require me to buy their book or product..actually i want to build on my own..do u know the web that can give me manual n component list?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Well, then have a look at this page:
    http://www.users.bigpond.com/cool386/tda7000/tda7000.html
    It's about constructing an FM receiver utilizing a TDA7000 IC and their variants.
    Here's a different FM IC, the Atmel U4065B:
    http://www.atmel-grenoble.com/dyn/resources/prod_documents/doc4807.pdf
    (requires Adobe Acrobat Reader to view, available at http://www.adobe.com )
    Those IC's will cut down considerably on the amount of time it'll take you to construct a receiver, but you should eventually consider building a receiver without the use of such highly integrated IC's.
  6. real_assassin85
    Jul 18, 2007
    8
    thx a lot...i will study that page..=)
  7. real_assassin85
    Jul 18, 2007
    8
    actually i cannot use an ic..i must build it part by part..can any one help me by giving me actual circuit without using ic to build fm receiver..
  8. JoeJester
    Apr 26, 2005
    3,403
    1,230
  9. GonzoEngineer
    Jul 8, 2007
    46
    Problems getting IC's where you live?
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Time to dust off the smith charts and take a refresher on complex conjugate matches.
  11. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A quick Google search using the terms "FM" and "receiver" yields several transistor-only (no IC) schematics.
    Or are you required to use tubes?
