New to electronics design, computer tech needs a schematic based on the simple TDA7000 ic to continuously scan through the frequencies! I have the TDA7000s, and YDA9088s but they are surface mounts. I can get most older ICs from a supplier in China so I'll take suggestions. I just need it as simple as possible. I have TDA2822s for amps, but I can get what is needed. I also have BB910 varactor diodes.
I just need an fm scanner to scan thru the frequencies and not lock on a station without having to be reset to continue scanning. And output thru an earphone and speaker. Also, I do not want to mute the scanning process. I need to hear the white noise as it scans.
Thanks!
Thanks!
