Fm receiver circuit using ic cxa1619bs follows which demodulation technique? Explanation of fm recei
Discussion in 'The Projects Forum' started by DEBPARNA MAJUMDER, May 17, 2015.
  1. DEBPARNA MAJUMDER
    May 17, 2015
    8
    Among the different demodulation technique exactly which method this fm receiver using cxa1619bs follows. Also explain this receiver circuit and function of all its components in detail .
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here is the functions list from the datasheet:
    Have a closer look at pin3, it uses CF3 for the discimination:
    Bertus
    DEBPARNA MAJUMDER likes this.
  4. DEBPARNA MAJUMDER
    May 17, 2015
    8
    Thank you so much for your answer. But I also wanted to know the function of every components in this receiver.
  5. DEBPARNA MAJUMDER
    May 17, 2015
    8
    I got my answer. thanks to everyone
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    Are you the same person with Asmita Nayak?
    This forum only allowed one person one ID, if you are the same person please decide which ID you would like to reserved ?
  7. DEBPARNA MAJUMDER
    May 17, 2015
    8
    Not at all. We both are working on the same project but the topics are different. She is dealing with transmitter and me receiver.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    Ok, thank you.
