FM Limitation
Discussion in 'General Electronics Chat' started by dhivyaraman, Jul 14, 2007.
  1. dhivyaraman
    Jun 8, 2007
    7
    Why the FM is limited to 88MHz to 108 MHz?
  2. recca02
    Apr 2, 2007
    1,211
    perhaps because other frequency ranges are reserved for other signals.
  3. jasonhaykin
    Member
    Mar 8, 2007
    23
    the frequency band you gave (88-108) is commercial FM.
    if you are building a fm related project, you can use any frequency for your transmitter/reciever.
  4. JoeJester
    Apr 26, 2005
    3,393
    1,211
    FM commercial Broadcasting is limited to 88MHz to 108 MHz, but FM [Frequency Modulation] is used in alot of other bands.
    You can use low power FM in that band, limited to a few hundred milliwatts without a license. All you would need is a quiet spot in the band. 47CFR covers the Telecommunications rules, commonly called the FCC rules and regulations.
    You can get a copy of the frequency allocation chart in pdf format.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    It was selected so as not to interfere with existing bands. That range of frequencies has changed drastically in it's history.
    http://en.wikipedia.org/wiki/FM_radio
    If not for rock and roll we'd still all be listening to AM.
  6. Gadget
    Jan 10, 2006
    613
    Land mobile services tend to use the band below 88Mhz, and Aircraft use the band above 108Mhz. Many countrys also put a limitation on output power and transmitter specs near the edges of the FM band (especially at the aircraft band end) to reduce the chances of interference to these services.
