FM frequency
Discussion in 'Wireless & RF Design' started by nerdegutta, Oct 30, 2010.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,565
    805
    I have built a FM transmitter. When I connect it to the computer speaker, and power it up, I hear it in my radio. And by turning the variable capacitor, the frequency changes.
    On my frequency counter, DVM13MFC2 from Velleman, the frequency shown is from 30-55MHz, according to the turning on the capacitor.
    The question is: Why do I hear it on the radio? Does the radio pick up the 2nd harmonic or something? I'm a little bit in the wild here...:confused:
    I'm aware of the law and regulations in the 88 - 108 MHz FM range.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    It is most likely the 3th harmonic.
    What are the dimension of the coil and the value of the Ctrim?
    Bertus
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    The coil is an air core coil.
    Diameter : 10 mm
    Length : 7 mm
    Turns : 4
    Wire: copper 0,5 mm
    Antenna tap in center.
    The ctrim is 6-70pF, I guess...
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Did you see this thread?
    http://forum.allaboutcircuits.com/showthread.php?t=7130
    To calculate the value of the coil, take a look at this page about aircoils:
    http://info.ee.surrey.ac.uk/Workshop...air_coils.html
    To calculate the resonance frequency take a look at this page of the AAC eBook.
    http://www.allaboutcircuits.com/vol_2/chpt_6/5.html
    I used the calculator from this page for the value of the aircoil:
    http://www.mantaro.com/resources/imp...calculator.htm
    I have done some little calculations:
    L = 100.440 nH (when dia = 6 mm and lenght = 10 mm and 6 turns)
    Lower frequency ( C = 30 pF) = 91.6 Mhz
    Higher frequency ( C = 5 pF) = 224.6 Mhz
    Middle frequency ( C = 15 pF) = 129.7 Mhz
    Greetings,
    Bertus
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    That's weird. I do not get the same numbers you do.
    Here's what I got:
    L=0.001N²r² / (228r + 254l)
    L=0.001 x 6² x 0.003² / (228 x 0.003 + 254 x 0.01)
    L=0.001 x 36 x 0.000009 / (0.684 + 2.54)
    L=0.000000324 / 3.224
    L=0.000000100
    Where do I take the wrong turn? :confused:
    I do not get the same numbers with this either...
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    As you can see I can even go wrong.
    Your calculations are correct.
    I found an other calculator page that also gives the value you calculated:
    http://www.mantaro.com/resources/impedance_calculator.htm
    The answer for the transmitter tread is 100.440 nH
    Your coil is : 136.939 nH
    I will correct the page also in that thread.
    With your coil and capacitor the frequency will be between:
    Ctrim = 6 pF : freq = 175.6 Mhz
    Ctrim = 70 pF : freq = 51.4 Mhz
    Bertus
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thank you. I can now stop pulling my hair... :)
    I got the same result with this formula:
    Now I'm back on track. :D
    So, by manipulating the coil, I can narrow down the frequency. Nice!
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    Hm... How did you get this? I've tried
    with no luck. *start-pulling-hair*
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    The highest frequency is :
    1 / (2 * pi * sqr(136.969 * 10^-9 * 6 * 10^-12)) =
    1 / (2 * 3.141592 * sqr(821.634 * 10^-21))=
    175.582 Mhz.
    The lowest frequency is :
    1 / (2 *pi * sqr(136.969 *10^-9 * 70 * 10^-12)) =
    1 / (2 * 3.141592 * sqr(9.58273 * 10^-18))=
    51.413 Mhz.
    As you can see the spread in frequency is large due to the large change in capacity.
    Bertus
  10. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thank you, Bertus. Now I got the same numbers.:)
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    If you make the FM transmitter on a pcb then add about 10pf of stray capacitance to everything.
    If it is made on a breadboard then add about 30pf to everything plus add stray series inductance to each wire. No wonder its frequency is too low.
    Most cheap FM radios are overloaded by a little FM transmitter close-by. Then the signal is received all over the dial and beyond.
  12. nerdegutta
    Dec 15, 2009
    2,565
    805
    all my RF projects are built on PCB I etch myself. I've read about stray capacitance, skin-effect and "micro-phony" in a few books.
    So far I've only noticed "micro-phony", but as long as the PCB is laying still, I'm not to bothered with it. I guess it'll be better if I mount the pcb in a metal casing, or if I put aluminum foil inside a plastic box I have. (as long as the foil is not connecting/touching the pcb.)
    I didn't know I should add 10pF.
    Thanks.
  13. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    As Audioguru said the frequency will go lower when the stray capacity is larger.
    The calculated frequencies are in ideal cases where there are no stray capacities.
    I have attached a PDF with a lot of information on RF prototyping.
    Bertus
  14. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks.
    This is a good document.
