No, it's wrong. The standard astable circuit is shown below;...
As crutschow mentioned, the circuit is based on a standard 555 astable configuration. I tested this circuit separately and the 555 outputs an offset (positive only) square wave as desired.
Note the difference to yours. In your circuit with the two equal 1k resistors, when discharge pin7 goes low the voltage on the cap C2 can only discharge to half of Vcc (due to the 1k:1k voltage divider).
It will not oscillate unless the voltage on C2 can charge >2/3 Vcc and discharge to less than 1/3 of Vcc.
Your faulty circuit might oscillate if the resistors were changed from 1k:1k to >2k:1k, ie that ratio may then allow discharge pin7 to lower the cap voltage to less than 1/3 of Vcc.
As your circuit is drawn, with those parts values it will not oscillate. Also it cannot oscillate AND run at 50:50 duty, as to reach <1/3 Vcc means the ratio of resistors cannot be 1:1, they need to be >2:1.
If you want a 555 circuit that works and makes 50:50 duty you can charge and discharge C2 through ONE resistor only, to output pin 3.
