Flyback transformer help
Garurumon
Joined Mar 17, 2013
99
My question is probably stupid, but heh, I don't know the answer.
So, I was bored and I wound this little flyback transformer:
http://www.youtube.com/watch?v=oeP6p3asED0&feature=youtu.be
Now, I'd like to make it a real "flyback", by adding HV diode and HV capacitor block so I can make a little plasma speaker, but I don't know what side of the secondary should I choose for the diode :D
1 wire melts, the other one is not melting, which should be connected to the diode?
This is the configuration:
http://upload.wikimedia.org/wikiped...entions.svg/250px-Flyback_conventions.svg.png
MaxHeadRoom
Joined Jul 18, 2013
28,700
I would think it would not matter, but if you are referencing the output to a chassis grounded circuit, it might be prudent to use the last conductor off the winding as the common?
Max.
Garurumon
Joined Mar 17, 2013
99
The intention is to make a somewhat stable DC output with only 1 cap and 1 diode, but I don't know which wire should I use for diode, and which for the ground.
I mean, once the mosfet is OFF, when magnetic field collapses, the energy contained in the core should choose the easiest way out, and that is through the diode to the capacitor, but I noticed that wires do not behave the same, and that is what confuses me, do i put it anyway I like it, or should I choose carefully after all?
Garurumon
Joined Mar 17, 2013
99
And btw, there will be no load, only secondary ends put a centimeter apart so the air is ionized and plasma occurs.
ian field
Joined Oct 27, 2012
6,536
Max.
With a flyback transformer, it matters a lot which way round the diode is - you have a 50% chance of getting it right first time, otherwise you end up with a low voltage forward converter that needs a diode with a huge PIV.
Garurumon
Joined Mar 17, 2013
99
Okay, so it's time for my paint skills. I attached a picture. Now, knowing the winding directions and how the voltage is applied, which of the following two should be done?
ErnieM
Joined Apr 24, 2011
8,377
Right side drawing of post #8 matches the phasing shown in post #1.
You can think of the phasing dot as the wire going a certain way around the core, and as long as you are consistent you are free to make that any choice you want.
ian field
Joined Oct 27, 2012
6,536
If you intend to create an arc, you don't want to rectify/smooth it. The internal impedance of the secondary and the breakdown potential of the gap will create a relaxation oscillator that discharges the capacitor at a slower rate than your converter switching frequency.
Garurumon
Joined Mar 17, 2013
99
But will the rectified arc be bigger?
I've done it before with DC flybacks and it was pretty cool.
ian field
Joined Oct 27, 2012
6,536
From around 15 - 20kHz onwards, you can generate pretty impressive arcs with surprisingly low (ish) voltages.
If the air between the electrodes is still ionised from the last spark, it doesn't need much for the next one to make it across.
BTW: what exactly is a "DC flyback"?!
A loose 24kV EHT lead in a CTV is theoretically DC because of the capacitors in the diode-split voltage multiplier, the 'capacitors' are actually the interlayer capacitance of successive layers of windings - so you could say it has a bit of ripple.
The loose EHT lead will draw a very long "whistling" arc - when connected to the large capacitance formed by the inner & outer conductive coatings of the CRT flare, that capacitance charges up via the relatively large internal resistance of the EHT transformer - if it has an (unintended) spark gap; it will crack over at much lower frequency than the horizontal frequency.
Garurumon
Joined Mar 17, 2013
99
By DC flyback I mean the real flyback topology, such as ones inside the CRT's, with inbuilt diodes and capacitors.
My transformer has nothing on the secondary side.
