Might be too high of voltage. 10 KV tends to strike and hold a pretty good arc.An old oil furnace ignition coil might work too.
The oil furnace igniters I've played with could strike ~3/8" or more. And are smaller than a neon sign transformer.Might be too high of voltage. 10 KV tends to strike and hold a pretty good arc.
The 2500 - 4000 volt NST's are pretty small so are you talking about a newer solid state furnace ignition modules?The oil furnace igniters I've played with could strike ~3/8" or more. And are smaller than a neon sign transformer.
There's killing bugs - and then there's obliterating them.There are ways to make the more complicated circuits work but why bother? All you want to do is kill bugs as reliably as possible for as little work and money as possible.
That's been a problem here a few times. Occasionally there will be so many bugs accumulated so fast they all light up causing a bug zapper fire which can lead to the whole plastic bug zapper body burning up and causing a grass fire underneath it. . My brother has had it happen at least twice I am aware of I have had it happen once.but you have to watch out for burning embers falling from the wire grille.
Wish I knew what old zapper transformer output was. How far should this one arc? If it's too much it'll be arcing all time.Should work fine assuming 2500 volts is high enough for your zapper. Many of the larger better-built ones can run up in the 3000 - 4000 range.
I say buy it and give it a test! I would think that 2500 volts should be enough to strike an arc through a bug.
Mesh wire diameter is .045", distance between grids is .5-.6"When I get the time I will put the one in post #9 together out of interest, this has the advantage of Triac level control.
What is the size of mesh and distance apart on a commercial one?
Max.
What's NST?The 2500 - 4000 volt NST's are pretty small so are you talking about a newer solid state furnace ignition modules?
NST = Neon Sign TransformerWhat's NST?
Any thoughts on this? https://smile.amazon.com/SainSmart-...&sr=1-4&keywords=high+voltage+transformer#AskNST = Neon Sign Transformer
An iron cored transformer has to be AC, a ferrite cored transformer is more like pulsed DC. A diode/capacitor multiplier won't work if you feed it DC, its output is more or less DC - but with a fair bit of ripple if you use textbook example capacitor values.Those are both DC output aren't they? Thought a 'zapper' needed AC or at least pulsed DC.
HELLO!! Anybody home? Y'all didn't die or get bad sick on me did you?At top is capacitor that is on/in the zapper HV lead to inner grid, next two are the unit it's on(one got in twice somehow) and the last is a similar unit which uses no capacitor. The capacitor does nothing when the VOM leads are reversed which tells me it's open. I've never dealt with HV capacitors, only 110-220 VAC ones for electric motors. Are these checked same way?
I "googled" the numbers on it and got nothing. How do you find these to buy?
No we didn't.HELLO!! Anybody home? Y'all didn't die or get bad sick on me did you?
Yeah, I did that stuff years ago, I'm into fixing old stuff now.No we didn't.
We all went out and got jobs at 1/4 that of minimum wage (some just begged for change on street corners. Other collected aluminum cans from road ditches. I mastered free energy and overunity in that time.) and have since bought multiple high quality bug zappers with that money we made since this thread started.
The tube didn't last long in the bug zapper I bought - I've bought replacement tubes from several sources with no better results. The ballast circuit could've been better - so I grafted in the PCB from a suitably rated CFL - still no better.Yeah, I did that stuff years ago, I'm into fixing old stuff now.
by Duane Benson
by Aaron Carman
by Jake Hertz
