flyback converter
Discussion in 'General Electronics Chat' started by pini200, Feb 28, 2016.
  1. pini200
    Feb 15, 2016
    14
    Hi
    i have a problem
    i build ac dc converter based on flyback and i get in outpout sawtooth with rippel 1v
    i should get stable voltage in outpout
    input: 110-230Vac,outpot 12v 1A
    i used chip viper37LD and isolated feedback
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    You could have Trr trouble in the rectifier - a Schottky barrier type is faster, as long as you keep within its low reverse voltage rating.
    You may also need a LC Pi network as the output filter, use wire about 2 - 3mm dia - about half dozen or so turns on a ferrite slug.
    The output filter electrolytic(s) need to have very low ESR - you could also add film capacitors in parallel, at least 0.22uF.
  3. pini200
    Feb 15, 2016
    14
    it does not help
    i think the problem with feedback chip
    If you have other suggestions?
  4. Dodgydave
    Jun 22, 2012
    5,143
    768
    Have you built this circuit or is it ready-made on a pcb?
  5. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    Are you sure you have the phasing right on that transformer? Could it be that you are rectifying the forward part of the pulse, and not the flyback?
  6. ian field
    Oct 27, 2012
    4,447
    791
    Forward conduction in a flyback converter would be obvious by the low output.
    If you increased the secondary turns to correct it - you'd soon find out if the rectifier didn't have high enough PIV rating.
