Flyback converter
ashwini
Joined Apr 22, 2008
Hi All,
I am trying to build a 100V to 12V DC-DC flyback converter.
Can anyone please help me in choosing the values for the Components???
Suppose if the switching frequency is 80KHz.
what should be the transformers turns ratio and magnetizing inductance??
what should be the value of output capacitor??
What kind of diode should i use???
please do reply.......
Ashwini
S_lannan
Joined Jun 20, 2007
246
If you read a book on power supply design you will find all the formulas you need to answer those questions.
'Power supply cookbook' by marty brown is a good one to read.
Caveman
Joined Apr 15, 2008
471
Go to magnetics inc. website. Look for their ferrite catalog. It has tons of info on magnetics.
But frankly, buy Brown's book. It will save you a ton of time.
The problem with switch mode power supplies is that they if they don't work, they often destroy themselves.
Good luck.
Papabravo
Joined Feb 24, 2006
21,225
Hi All,
Ashwini
That sounds more like a buck converter. Why are you using the flyback topology to lower the DC voltage?
IMHO you have no chance of succeeding using online resources. Buy the book and be done with it.
Caveman
Joined Apr 15, 2008
471
Just FYI, the flyback topology is used quite a bit with offline power supplies to step down the voltage, so this may be the right topology to use with this big of a step down.
Ashwini, you have to realize that there are people who spend their entire careers on this stuff. SMPS put semiconductors in situations where the assumptions (most of which you don't even know you are making) don't work.
Let me just give you one example. In a buck converter, the diode does conduct current in the reverse direction during every cycle. No it's not a special diode. In fact, normal diodes like 1n4001's are the worst offenders. Get the book. Trust me on this one.
Papabravo
Joined Feb 24, 2006
21,225
I've been doing SMPS for some time and I was unaware of this feature of the flyback topology. Maybe I should go buy the book. Hmmmm.....
Caveman
Joined Apr 15, 2008
471
It's just a method of reducing the requirements of the switch voltage swing. The transformer turns ratio handles it. The other common reason is for isolation purposes.
jpanhalt
Joined Jan 18, 2008
11,087
I wanted to let you know I bought THE book by Marty Brown, $38 USD new and including shipping.
I have only had a chance to look up a few things and skim others, but it is well worth the money. I particularly like the stepwise instructions for design, notes about potential potholes (e.g, the differences between snubbers for power supplies versus SCRs, page 146), and clear, instructive language. Thanks for the lead. John
