Flyback Capacitor Charger Question
Discussion in 'The Projects Forum' started by airplane100000, Sep 20, 2016.
  1. airplane100000
    Aug 2, 2016
    60
    Given the following example:
    A flyback converter charges a 10nF capacitor to 4kv. When a 100k load is attached to the charged cap it discharges in ~3ms. Now with the load attached, the cap no longer charges to 4kv, it instead delivers a more or less steady 500v to the load. Only when the load is disconnected will it charge again to 4kv.
    My question: Is there anyway to replicate the connecting and disconnecting of the 100k load without doing so physically. In other words, is there a way to allow the cap to charge to several kilovolts before discharging.
    Thanks for any help!
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    I don't see you could not do it physically. :confused:
    You could use a hypothetical high voltage switch or relay to disconnect the resistor during charge.
  3. airplane100000
    Aug 2, 2016
    60
    Could you use a varistor in series before the load, which would show high resistance when the cap is at a low voltage and lower resistance as it charges up? Or is that a foolish idea...
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    Likely nothing that would stand 4kV.
  5. AlbertHall
    Jun 4, 2014
    2,271
    449
    You could use a PL504 (rated to 7kV) to switch it.
    Thermionics make a comeback.
