fly back transformer wiring help
Discussion in 'The Projects Forum' started by Slink, Dec 4, 2012.
  1. Slink
    Dec 4, 2012
    ive got a LG 6174Z-1012B flyback transformer and i need some help with the wiring, there are 10 pins on the bottom and i need to know which ones to wire up :)
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    Do you have a data sheet for that transformer? Without that it would be difficult to determine how to wire it.
  3. Slink
    Dec 4, 2012
    sorry i do not :/ all i know is that there are ten pins and three wires. sorrfor the lack of info
  4. alim
    Dec 27, 2005
    113
    Hi are you replacing the transformer on the board? Or are you hooking up the the transformer to carry out a test? If you are replacing the transformer, install it and properly solder the 10 pins , the 3 wires one will be the screen voltage ( the finest one ) on the CRT board, the second sized one is the focus voltage and it goes to the CRT socket the third is obvious.
  5. Slink
    Dec 4, 2012
    na the transformer is for a test :p
  6. alim
    Dec 27, 2005
    113
    Can I ask you what test you want to carry out?
  7. Slink
    Dec 4, 2012
    tesla coil constrution
