Fluke clamp-on ammeter repair
Discussion in 'General Electronics Chat' started by Jaguarjoe, Sep 7, 2011.
  1. Jaguarjoe
    Thread Starter Active Member
    Apr 7, 2010
    770
    90
    I have a Fluke i410 clamp on AC/DC current adapter for Fluke DMM's. It has worked flawlessly for many years but has now bitten the dust. It always puts out 4vdc.
    Is there a place to obtain schematics for this kind of stuff, or a place that can repair it for less than an arm and a leg?
    Thanks,
    Joe
  2. debe
    Sep 21, 2010
    955
    185
    Typical AC/DC current clamps use a linear hall device to measure the current. Sounds like the hall device is faulty if its stuck on 4v.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    I sold the Jag so I guess you could call me the Flukemiester now. I took that clamp on unit apart today. It has an 8 trace flexible pcb terminating in a 8 slot connector. It was loose. I had a hard time reconnecting it because it was very short and very small. It was almost as hard assembling the rest of it.
    A big reason their stuff is so expensive is that it is not designed for manufacturing.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    I've got a bad one also. maybe that's my problem.
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
    You can't break it anymore than it already is, go for it!
