fluid level
Discussion in 'The Projects Forum' started by picit, Aug 19, 2008.
  1. picit
    Dec 14, 2007
    7
    I have a water tank (4'x4' x3' )that i want to bury up hill from my camp and fill it with a well pump and generator and then gravity feed camp so i won't need electric running.
    My problem is knowing water level in tank. Is there a variable resistor that works on a cable, so i can mount one end on a float and the other end on top of tank?
    Any other ideas would be helpful
    thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Two float switches might be more simple. The lower turns the pump on when it falls, and the upper turns it off when it rises.
  3. picit
    Dec 14, 2007
    7
    THanks beenthere
    I'll try that if i can't find way to read the full swing 1/4,1/2,3/4 like a gas tank.
  4. kammenos
    Aug 3, 2008
    127
    You want to know 1 or two levels? Or exaclty the level ? I mean, you could use a probe or two (like beenthere said) but if you want to have an analog signal, then you sjould consider using a pressure sensor. Water is what you will fill the tank?
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    One can purchase resistive water level sensors which function similarly to automotive gas tank sensors. Here is one example: http://www.wemausa.com/tank_sensors/tank_level_sensors.htm
    They are a bit expensive, especially when compared to a ping-pong ball on a stick with a hand-full of scrounged micro-switches.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    External hardware amy be hard to maintain, as the tank is going to be buried.
    Question - is it important to know the fill level, or will it be enough to insure the tank is never empty?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, the S3U with a 35" vertical dimension is $69, and then the OP will need the $4 adapter plate for mounting it. It's made from 316 stainless steel, so he should get a long and trouble-free lifetime out of it - if the interface electronics are properly designed.
    It has 240 – 30 ohm operation; that seems to be in the ballpark range of a typical fuel tank level sender. He wouldn't even have to build any electronic interface if he didn't want to - just run a couple of wires down to the camp, and use a multimeter set to read Ohms. 30 Ohms = nearly empty, 240 Ohms = full. Since a 4'x4'x3' tank holds 359 gallons, if the OP multiplies the Ohms x 1.5, they'll get a pretty reasonable estimate of how many gallons are left.
  8. picit
    Dec 14, 2007
    7
    Thanks All
    The tank will be underground but will be accessible. The S3U looks like it will fit the job as i already have 3 wires buried up to the tank.
    Thanks again
    Picit
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'd go for that solution myself. It'll be worth a few extra bucks for the extra reliability.
    Don't forget that your wire that you ran will have some resistance to it. Exactly how much depends upon the wire gauge and the total length of the wire (round-trip). You'll need to subtract that wire resistance to get the actual resistance of the level sender.
    If you're going to bury the connection at the water tank, better use waterproof heat shrink tubing; the kind with glue inside. Electrician's tape is garbage; it'll fall off in a few months. Silicone RTV is corrosive; it emits ascetic acid as it's curing.
  10. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Its not "garbage," anymore than a butter knife is "garbage" when a screwdriver is called for. Butter knives work quite well for spreading butter or jelly, just not for putting in screws. Electrician's tape is perfect for temporarily securing cables or wires onto a pull-string or fish-tape. The colored varieties are good for identifying cables. It should never be used as an insulator, though.;) Use "self-fusing silicon tape" for insulating.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yeah, OK - it does have some minor (and temporary) uses; just not for what most people think it should be used for. ;)
    I found some guy last summer using electrician's tape on a homebuilt aircraft. :eek: I nearly had a conniption fit.
    I personally love the self-fusing silicone tape, but it's difficult to find, and takes some practice before one can apply it properly.
    The heatshrink with the glue inside is relatively easy to use, and won't leak for quite a while.
  12. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    YIKES!:eek: Step away from the aircraft, Sir!:cool:
    Yes, now that you remind me of it, I do recall a bit of a learning curve for the silicon tape. For a one-off, the goo-tube would indeed be better.
    For finding the self-fusing tape, try asking for "tommy tape" or "wrap fix" at your local hardware or farm supply store.
