FLRDs needed
Discussion in 'General Electronics Chat' started by 8-bit, Jul 13, 2014.
  1. 8-bit
    Jan 7, 2014
    27
    I'm UK based and I am trying to get hold of some FLEDs to use on some solar bots but I can't seem to find anywhere that sells them. The only ones on EBAY are coloured ones, are they okay to use?
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    All LEDs are colored. What color are you looking for?
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    what's an flrd?
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    The title says FLRD (not FLDR), but I think he meant FLED (as mentioned in the actual text), a.k.a. a "Flashing LED". I'm assuming this is what he wants, but I'm not sure.
  5. 8-bit
    Jan 7, 2014
    27
    Typo, sorry.
    Yes, I meant flashing LED. The one they are using in the circuit is white so I am just assuming that is what you need. I have no idea myself, I am just following the build. :)
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I would guess if there was any difference between a flashing white LED and a flashing red one (for example) would be the forward voltage drop of the LED itself, but I expect the internal flashing circuitry would take care of that. Just check the datasheet and make sure it fits your requirements.
    8-bit likes this.
  7. Dodgydave
    Jun 22, 2012
    5,155
    772
    Ebay do white ones also
    8-bit likes this.
  8. 8-bit
    Jan 7, 2014
    27
    Hey thanks Dave! Not sure how I missed those! :)
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
    And here I thought you meant Flexible Light Emitting Diode.
    I think if you would describe what you really want instead of relying on ambiguous abbreviations, it would help us help you. Have you looked at Hobby King? Please give more details about the number of LED's you want to drive, flash rate, colors, and so forth.
    John
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Good catch! :)
    When people start getting letters wrong in acronyms all hell breaks loose. :eek:
    DerStrom8 likes this.
