Flow rate with respect to opening
Discussion in 'Physics' started by hardernail, Sep 20, 2005.
  1. hardernail
    Aug 25, 2005
    6
    [attachmentid=900]
    hello,
    I'm looking for the flow rate equation for the following situation. The stopper rod covers the hole, but when opening has an exponential flow rate. I dont have any values as of now but when I do get them I would like to be able to just plug them into the equation and get results. If there is anyone who could help me it will be great. The equation for a flow rate through a pipe is Q=VA
    Q=flow rate
    V=fluid velocity
    A=cross-sectional area
    The hole that the stopper rod covers leads to a pipe. The stopper rod will not raise above 85 mm. Thanks for the help.
    craig
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Take a look at this web site and see if contains the formula you need.
    Engineering Formulas
    hgmjr
  3. hardernail
    Aug 25, 2005
    6
    This site helped a little but you were limited to the amount of time on it. So there was little progress made.
