I don't understand really about floating voltages VS grounded voltages
if your using differential signals they use Floating voltages but why ?
When the differential signals go to the op amp they get converted from floating to ground , because inside the IC chip the differential signals get grounded
I'm not understand the potential differences when using floating
Is floating = difference signals DC or AC?
I seen DC floating to DC ground converters , but why would circuits use DC floating voltages?
I'm not understanding really what are Floating voltage dividers or floating voltage drops
How do you measure floating voltage drops ?
I would think the using DC floating would create alot of noise/buzz/hum is this true?
How do you know the potential differences when measuring floating voltage drops?
Is seems that Floating is DC offset with AC signal because your not grounding the DC offset ?
Is floating always differential signals? if what does floating mean to AC and DC signals?
Whats the difference between a floating power supply VS a reference power supply? why would i use a floating power supply?
