floating voltage and solid state relay
Discussion in 'General Electronics Chat' started by Lubby, Sep 9, 2010.
  1. Lubby
    Feb 20, 2007
    6
    I'm having an issue with a Solid State Relay triggering with the slightest floating voltage when using a transistor or mosfet - and if I do without and trigger the SSR directly from an arduino it will not fully engaging.
    Is there a way of clipping voltages or current that would to setting the transistor off?
    I'm fairly green at this. Maybe a FET or something else that requires a minimum voltage of 4v would be better? It there other switching devices that can be put in front of the SSR?
    thanks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post your circuit?
