floating point multiplication/division
Discussion in 'Embedded Systems and Microcontrollers' started by manikanta.mashetti, Jan 13, 2014.
  1. manikanta.mashetti
    Jan 13, 2014
    Iam Implementing a FPU(floating point unit in a simple CPU),In this when I want to do multiplication ,Iam unable to calculate how many clock cycles it will take.The problem I explained below very briefly .
    I have read some algorithms ,in this (briefly) the result of multiplication is:
    1.sign bit=s1 xor s2
    2.exponent=e1+e2-127
    3.mantissa=m1*m2
    1,2 steps are ok but in the 3rd step they are doing integer multiplication I will do this using repetitive addition using shifting.but all this is a combinational logic there is a no clock playing a role here .so how should I consider the delay, though this comb delay may be large than the clock period and how can I decide this comb delay .
    similarly in the division also ..
    shall I consider 1 shift is equal to 1 clock period such that in multiplication maximum 48 clock cycles it will take.or shall I consider some shifts(1,2,3,4,5,6,7,8) equal to 1 clock cycle.
    Thank you,
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    What CPU or MCU are you using?
    Which compiler are you using?
    Show your code.
