Hello all. I was wondering how to connect unit that is floating ground to dc ground with out damaging unit. can any one give me suggestions please. Thank You Kindly. Happy New Year
Sometimes items use a "floating" ground due to how they're connected to the power supply.
For example, a typical PC ATX-form factor power supply has no designated +7V output, although by connecting a component between the +5V and +12V outputs one can realize a 7V difference in potential. In this case, the +5V is now a "floating virtual ground" to the component. If you attempted to connect this "floating virtual ground" to chassis ground, you would place a direct short across the +5V supply.
