Hi guys
I want to turn a 3 phase pump on and off automatically with a float switch level sensor the motor is just a small 1kw motor controlled through a standard telemc contactor. I have attached links to the level switch i will be using along with the relay and relay base that i will be using too. i just need to know the connections or if possible and ideally a schematic of how to wire this in so the pump turns on at low level and stops at high level automatically.
Thanks guys
http://ie.rs-online.com/web/p/level-sensors-switches/0339730/
http://ie.rs-online.com/web/p/non-l...573743D333533393136267374613D3033353339313626
http://ie.rs-online.com/web/p/relay...573743D333533393636267374613D3033353339363626
Thanks guys
