Flip Flop Freq Divider
Discussion in 'General Electronics Chat' started by Tobias, Jul 18, 2011.
  1. Tobias
    Thread Starter Active Member
    May 19, 2008
    158
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Your question is not clear. Which one of the two ICs are u using?
  3. MrChips
    Oct 2, 2009
    12,633
    3,453
    The PDF file you attached is for MC10EL32/MC100EL32. If this is the chip you are actually using then don't expect it to work. This is an emitter-coupled logic (ECL) gate and is not compatible with TTL or CMOS voltages.
    You may want to use a TTL D-flip-flop such as 74LS74 or a CMOS type such as the MC14013B, or 74HC74 etc.
  4. Tobias
    May 19, 2008
    158
  5. MrChips
    Oct 2, 2009
    12,633
    3,453
    Ok. Make sure that you tie all unused inputs to GND (Vss) including the inputs of the unused flip-flop.
  6. praondevou
    Jul 9, 2011
    2,936
    489
    What output signal exactly do you have?
  7. Tobias
    May 19, 2008
    158
    Its mainly high. I have a variable power supply. I have tried keeping the square wave at 5v and move the VCC from 5V to 12v. It doesn't change much either. I have a couple of the flip-flops too, so I don't think its a bad component. In a couple hours I will be able to try tying all the un-used inputs to ground. thanks
  8. praondevou
    Jul 9, 2011
    2,936
    489
    As Mrchips said: RESET and SET have to be tied to ground.
  9. Tobias
    May 19, 2008
    158
    That did it, thank you. Reset and Set needed to be tied to ground. Thanks again
