flip flop counter
Discussion in 'Homework Help' started by everest86, May 24, 2014.
  1. everest86
    May 19, 2014
    How to make a D-flip flop down counter count from 5 to one on schematics???
  2. saraswathi.95
    Member
    Apr 11, 2013
    40
    Prepare a state transition table with present and next states you may require 3 D flip flops
    You can select appropriate inputs to that d ff's using excitation table of d ff as follows
    present_state next_state D
    0 0 0
    0 1 1
    1 0 0
    1 1 1
    using this table prepare input combinations to all flip flops
    then using k map prepare equation for each input to d flip flop which is a function of different state values.
    prepare schematic , it is so simple.
    give all the outputs to nor gate and connect nor gate output to clear input of all the flip flops so that counting stops after 0 is encountered.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Give this thread a read. It describes how to make a synchronous, mod-10 counter, but the idea is the same regardless of whether it is an up counter, down counter, gray code counter, etc. If you understand the process, you can make it follow any kind of state transitions you want.
