flip flop circuit using c828 transistor need diagram
Discussion in 'General Electronics Chat' started by jeysandoval, Aug 16, 2008.
  1. jeysandoval
    Aug 15, 2008
    hi..can anyone help me in building a flip flop circuit using a c828 transistor? Ive been searching diagrams in the internet but found nothing..any help would be appreciated..
    thanx...
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Define the C828, a datasheet would be a good start, that or a general description, such as an NPN silicon transistor. Generally you only need the basics, such as the NPN silicon BJT, to define a circuit, unless there is something really special about this part.
  3. jeysandoval
    Aug 15, 2008
    thanks,,
    the c828 is a transistor, our instructor had given us a diagram but I think the diagram was wrong,.we had tried it in our breadboard but it doesnt work, some of our materials were 12 leds, 16v/100uf capacitor, 100ohm resistor, etc..
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A 2SC828 is an NPN transistor in a TO-92 case, vaguely similar to a 2N3904.
    http://www.alldatasheet.com/datasheet-pdf/pdf/108447/ETC/2SC828.html
    Note the different arrangement of the leads. With the flat side of the TO-92 case facing you and the leads down, the emitter is on the left, collector is center, base on the right. The collector and base are swapped as compared to a standard 2N3904.
  6. kammenos
    Aug 3, 2008
    127
    Hallo
    Are you sure it is a transistor? Because i found a book that it has equivalent to equivalent to BTA41-40 and that is a triac.
    You can check if you want here to see if is a transistor.
    http://pcbheaven.com/workbench/istransistorworking/
    Sorry if i am wrong
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    As you can see, we still need more information, such as the complete transistor part number (I'm inclined to go with Wookie's assessment), and what kind of flip flop, Set Reset, Monostable, or Astable. We also need the schematic to be of much help.
