I was planning on using it to make a motor for a milling machine, to cut metal and wood. So it’ll probably need a high torque and rpm. Do you have any suggestions on what I should use, and any tips for making the electromagnets? Thanks!
According to the Instructables article, down to 4.7u has been tested. That doesn't mean you can't go lower .What is the minimum I can reduce these to?
