Flip Flop Characteristic Equations
Discussion in 'Homework Help' started by n0th1n2b3sa1d, May 27, 2009.
  1. n0th1n2b3sa1d
    May 27, 2009
    An easy one.
    I just try to understand how I can write a flip flop's characteristic equation with using its characteristic table ?
    Could you explain how can i implement J K flip flop characteristic equation, with using J K flip flop characteristic table ?
    http://faculty.kfupm.edu.sa/COE/ash.../COE022_200/Chapter4_1_files/jk-flip-flop.gif
    My major job is about implementing the characteristic equations of custom(user defined) flip flops, whose characteristic table is given. I thought that J K ff would be a good example for me.
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do you mean a truth table? Could you explain what you mean by -
  3. n0th1n2b3sa1d
    May 27, 2009
    for example i have a 2 input flip flop which is states are :
    when 1, 1 = set state;
    when 1, 0 = reset state;
    when 0, 1 = complement;
    when 0, 0 = no change.
    i can draw its characteristic table, but i don't know how to get characteristic equation from its characteristic table.
  4. n0th1n2b3sa1d
    May 27, 2009
    By the way, yes. I meant the truth table, which belongs to characteristic equation.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You may notice that there is also a clock input involved. Your typical J - K flip flop does not operate according to you table. You will need some external gates to control the J and K inputs so the flip flop will act as you wish.
    Look up the data sheet for a 74XX73 to see how a J - K operates.
  6. n0th1n2b3sa1d
    May 27, 2009
    thank you.
