Flickring LED
Discussion in 'General Electronics Chat' started by m.levin, Jun 23, 2007.
  1. m.levin
    Jun 23, 2007
    This is my first post on your forum, so I would like to say hi. 1 of the nice names I have is martin, but feel free to call me what you want ;) I want to make a flickering LED fire, for a model railway layout. I have made one using 2 555 times and 2 LED’s, I played about with the circuits to get a "something like effect". I am new/in my first year of electronics and would like to know if it is possible to make this circuit using 1 IC and 1 LED? The circuit I made is a bit on the large side and I would like to reduce it as much as possible.
    Martin
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    Yes. You just have to use one 555 timer IC and one output LED (sourcing or sinking current. You can see in the "Projects Collection" a project that uses a 555 timer IC. Look for "Stroboscopic LED light". Also, you won't need t transistor, since the LM555 can source up to 200mA, more than enough to drive a LED.
  3. m.levin
    Jun 23, 2007
    has anyone a wiring diagram?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is an LEB throbber circuit.
    You can use is to get some ideas.
    hgmjr
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  6. Gadget
    Jan 10, 2006
    613
    I recently had to make flickering lamps for a goldmine display (a substitute for old kerosene lamps). I used a PICAXE8 (8 pin pic) a surface mount 5 volt reg, and drove a 20 watt 12v capsule lamp via a Mosfet for each unit.
    Was a tidy wee circuit, all fit inside a piece of heatshrink and the programming was quite basic.
