I am making a moving platform that has motors on it. I need some really flexible wire to power the motors with. It has to have a lot of give to it, so that the wire doesn't behave like a spring and effect the movement of the platform.
The motors are rated at 1A, but I doubt I will be loading them anywhere near that much. Separate conductors are ok. The wires will be about a foot long and there will be two of them for each motor. I also need grounding straps that are about three inches long.
Any suggestions for the type of wire I should use?
Stranded obviously, but is there any special types of wire with really flexible properties that can handle the current?
