Flexible Flat Cable Connectors
Discussion in 'The Projects Forum' started by jpanhalt, Jan 3, 2015.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    128X64 GLC displays often come with 2-mm pitch contacts for the 20 pins needed to control them (parallel). In the past, I used a laptop HD drive adapter to get from the 2-mm spacing to 2.54-mm spacing of common double-row, 40-to-44 conductor, gray flat cable. It works, but is bulky.
    I think FFC in 1-mm pitch would work fine in my application and save space. We have all seen that cable. Here is a brief review of its history: http://www.avx.com/docs/catalogs/ffchist.pdf
    The problem is what to do with the 2-mm pitch of the GLCD. Molex sells connectors for 0.3 mm, 0.5 mm, 1.0 mm, 1.25 mm, and 2.52 mm cable. I cannot find 2-mm pitch connectors or cable. One option is simply to make an adapter board to go from 2-mm TH contacts to a 1-mm FFC connector for the cable.
    Any other options?
    John
    UPDATE: Just got from China a new display. It has the PCB traces and soldering pads already present for an FFC connector (1-mm pitch). So, the issue has pretty much evaporated for this particular display. Now, if it actually works...
