Hiya!
I'm making flashing white leds mounted to the ceiling of out sauna. There should be about 30 to 40 leds and in flashing groups of two (or three if possible). Duty cycle should be near 50% and the time between two flashes should be something like 2-3 seconds. Also I don't want the leds to flash between on and off, preferably like 50% brightness to full brightness, like flashing stars.
So far i have breadboarded few designs, one used only two alternating leds and with brightness going from 0 to 100, and the other only one led, but the fading cycle and brightness were what I'm looking for.
I guess this is what I'm looking for, but how can I make the brightness go as wanted. The cap value changes the rate so that shouldn't be the problem (right? ) Hopefully someone understood what I'm trying to make, so you can push me in the right direction
Thanks in advance!
Thanks in advance!
