What I am doing is using a car stereo amplifier, and using the output voltage from that amp (just putting wires in parallel with the wires to the sub) as the control voltage for a MOSFET. The MOSFET will then let the 12v LED string light up. It seems to be working incorrectly though. Is it possible to switch a DC source with an AC signal voltage from an amp?
Here is a photo and a schematic of my circuit. I first divide the output voltage from the amp, but I use a dual potentiometer to give me theoretically a wide range of input voltages that can cover a specific range of output voltage to the MOSFET. According to my calculations, the selected values should give me let me adjust input voltages from 8-30V to output voltages from 1.6-3.2V, which after testing is the approximate gate voltage range at which my MOSFET went from fully off to fully on. In this way, whatever volume the music is at, I should still be able to make the lights flash at the same brightness.
The problem is that the MOSFET seems to be turned on using only the negative speaker output from the amp, bypassing the voltage divider. This circuit will flash the lights to the beat of the music, and the pot will vary the brightness slightly, but if unplug the positive voltage from the amp, there is no effect on the circuit. It seems to be run entirely from the negative terminal on the amp, and I don't understand how/why this is happening. Can someone help me understand what is happening?
Note: If I remove the voltage divider, and set up the circuit as in "Circuit 2" the lights will not flash at all if both positive and negative wires are attached from the amp. However, if only negative is attached, it flashes with the beat fairly well.
