Flashing LED's
Discussion in 'The Projects Forum' started by RodneyB, Oct 3, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    648
    14
    I have some flashing LED's and just want to enquire if the frequency they flash can be changed. Also can they be connected in series and do they require a series current limiting resistor?
    Many thanks
  2. wayneh
    Sep 9, 2010
    12,382
    3,238
    No specs, manufacturer, source, or photo? Tough to guess what you have.
  3. Bernard
    Aug 7, 2008
    4,240
    414
    If the LEDs flash with application of power, then freq. is fixed & no change is possible. In series results might be strange, un intentional operation. Yes , current limiting is needed.
    RodneyB likes this.
  4. RodneyB
    Apr 28, 2012
    648
    14
  5. adam555
    Aug 17, 2013
    858
    39
    I bought similar ones by mistake and no, you can't change the frequency varying the voltage; you will only get some colors not working at lower voltages (e.g. blue).
    Besides that, they work as any other LED; so yes, you can connect them in series, and the resistor depends on the voltage applied.
  6. djsfantasi
    Apr 11, 2010
    2,905
    878
    If they are connected in series, you will see some strange results, if anything at all. If you want several LEDs to flash in unison, one can make a series string of a resistor, a flashing LED and several standard, non-flashing LEDs. The quantities and resistor values depend on your design and it's power source.
    If this is not what you're looking for, Nevermind.
    RodneyB likes this.
  7. RodneyB
    Apr 28, 2012
    648
    14
    Thank you one and all for your advice and assistance.
