Have you taken into account the voltage drop in the NE555P output stage? this is about 2.5 Volt at 200mA. If you have calculated the LED series resistors without taken the latter voltage drop into your calculations. Each LED will have lower current than calculated. You will have less brighter LEDs. But your 555 will probably be inside the 200mA spec
