Hi all,
I'm after a circuit diagram for a flashing LED circuit. I've done a search and come across this:
I've got a few questions about the circuit. Firstly, as you can see this circuit diagram is intended for 6v use, however I want to power it from 12V DC. What values do I need to change and to what? Next, I would like it to flash from one LED to the other, is this the correct configuration? And next, what (if any) values to I need to change to have the flash rate at one per second, and what to?
Any help is very much appreciated,
Cheers,
Heinz
Cheers,
Heinz
