Im currently making a light box circuitry project that I need to finish for next Wednesday and I am having a few problems with the design of the circuit. It is required that the light box pulse in time with the music however I am working with a low budget and have relatively low skill level so in that respect simplicity and cost effectiveness is the key.
As an initial basis I was going to use this circuit, http://hacknmod.com/hack/led-light-box-thumps-to-your-music/
although I have a few questions with regards to its functionality. I assume that I will have no problem modifying the circuit for a 12v wall socket set up, and although the LEDS are different to the ones draw I cannot see there being any issues of connectivity of the circuit.
I do however want to change the connection to the Tip 31 transistor to a microphone instead of a phono cable. Will this still work with the tip 31 transistor? I will also require a volume control for the microphone so that I can alter the sensitivity of the pick up dependant on the surrounding volume.
Thanks in advance for your help,
