flashdrive programmer help
Discussion in 'Programmer's Corner' started by jerone, Sep 6, 2008.
  1. jerone
    Aug 30, 2008
    15
    I forgot to remove my flash drive while formatting my PC. When Im done, I wonder why my flash drive wont work anymore. I think this is also formatted together with my hard drives. And maybe its internal program is also deleted that is why it cant be used anymore. Can I load a program to this thing so that it will function again? And if you have this programmer,can I ask for it? Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Does it still show up in the drive list when you plug it in (assuming this is not a Mac)? If so, can you save a file to it? Don't see why a Format C: command would bother a flashdrive in as drive F.
  3. mentaaal
    Oct 17, 2005
    451
    What version of windows are you using? Does anything happen at all when the device is plugged in? Have you tried your device in another pc?
  4. jerone
    Aug 30, 2008
    15
    Yeah it would still show up but i cant save a file anymore. 0 bytes free,0 bytes in use.im using windows xp. If ill format it in the (my computer), it wont finish. An MMC also is plugged in for my N70 nokia phone during the incident. Now it shows memory card corrupted.I formatted it in my phone,it would finish but still shows memory card corrupted.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Since you say you were formatting the drive, were you reloading the OS? If so, did all the motherboard drivers get reloaded? Does the Device Manager say it is happy with the state of all the hardware resources?
  6. jerone
    Aug 30, 2008
    15
    yup im reloading the OS and its drivers. . . if another flashdrive will be inserted,it functions normally.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  8. jerone
    Aug 30, 2008
    15
    Thanks SgtWookie.
