flash programmer
Discussion in 'Embedded Systems and Microcontrollers' started by munna007, Aug 16, 2008.
  1. munna007
    Thread Starter Active Member
    Jul 23, 2008
    51
  2. munna007
    Jul 23, 2008
    51
    atleast tell me plz if i need additional programmer to load firmware into it????
  3. Arm_n_Legs
    Mar 7, 2007
    183
    10
    If you are using AT89S51, AT89S52, or AT89S53, you can build the downloading circuit into your final application circuit. You does not require a separate programmer to burn the code into the flash.
    Check out the link below. The software for downloading is also included.
    http://chaokhun.kmitl.ac.th/~kswichit/IspPgm30a/ISP-Pgm30a.html
