Flash Led
Discussion in 'General Electronics Chat' started by FroceMaster, Sep 16, 2014.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi
    Need a simpel Circuit to make a LED flash,(4 in parellel)
    i know i will need 4 resistors on 330 Ohm,
    i have a 5v aoutput, 20 mA
    Have can i make that, blink 2 times a second, 2 times off and 2 times on each second, aproxx.
    Simpel as possible,
    Correct, have 5v 20 mA as control and 5 v 1A total.(allways on)
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    So you have a 5V supply and want to flash 4 LEDs. In parallel, they will all flash together. Is that OK?
    I don't understand your blink pattern. Are you saying you want it to flash at 2Hz, on and off twice each second? Roughly equal on and off times?
    When you say your supply is 20mA, is that the total output capacity? That allows only 5mA for each LED. They will light with that, but it's not much.
    Do you have any parts already? You could use a 555 timer or an op-amp to build your flasher. A transistor may also be needed.
  3. FroceMaster
    Jan 28, 2012
    402
    Transistor is ok to use, but not a 555, yes 20 mA it total output from mu MCU. have access to 1A.
    use only resistor , cap and transistors., and yes all blink together, common ground. on all leds.
    1 Hz or 2 or 3 is all ok.
  4. Bernard
    Aug 7, 2008
    4,231
    414
    Does your MCU supply a 2 Hz signal? 330 ohms seems large, @ 2 V - Vf - & 330, would give only 9 mA. Do you really want the LEDs cathodes @ ground or just connected together? For consideration: MCU is supplying a 5V P-P signal thru a 510 ohm resistor to the base of a NPN transistor, 2N3904 etc., emitter grounded, collector to 4 LED cathodes, LED anodes each to a 330 ohm resistor, other end to 5V, 1A supply.
  5. FroceMaster
    Jan 28, 2012
    402
    have designet this
    this is how the leds will be connected, and i will use the MCU as "flashing".
    but i can only Draw 20-25 mA from MCU, Thats why i need this.
    what value for the resistor to base ?
    eason for use BC337 : have 10 of them, ;)
  6. wayneh
    Sep 9, 2010
    12,368
    3,224
    The base resistor should be sized to allow up to 10% of the load current to pass thru the base. This ensures it is turned on hard and will have minimal series resistance.
    So R =10 x ∆V/I load. Assuming your 4 LEDs are running at 15mA each, R = 10 x (5-0.6)/0.06 = 733Ω. I'd probably choose a 820Ω or maybe even a 1K.
    You can use a larger base resistor if you are indeed running the LEDs at just 9mA each.
  7. FroceMaster
    Jan 28, 2012
    402
    Thanx 1k i have.
  8. Bernard
    Aug 7, 2008
    4,231
    414
    1k should be fine.
    Wrote yesterday, forgot to hit Post Reply?? Another marble down the drain. They are getting in short supply.
