Midway through a run my treadmill stopped working - however the power was still on as was the LED display, but the motor stopped turning.
I took the front off where the motor sits and it was incredibly hot. I assumed it must have overheated or burnt out due to too much stress. I unplugged the treadmill and left it for a few hours but with no difference.
If I turn it on it seems fine, and if I start the treadmill the counter will even increase as if I am running, however the motor will not turn.
I took out the motor and cleaned the treadmill, and then put in a new motor. However I still could not get it to work, even though everything appeared to be on. I also noticed the heart rate monitor was spazzing out and saying my heart rate was over 150BPM, even when I wasn't running, which led me to believe it is an electrical malfunction.
I had a further look on line and read something about burnt resistors. Sure enough it looks as if one of the resistors is burnt and there is a blackish stain on the control board.
This is a Chinese branded treadmill without any information supplied. I cannot find any information about it on line either.
Would be grateful for some advice on this as to what people would do next - I don't have much knowledge of small electronics or any specialist tools.
