MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
A zener is only a two terminal regulating device. but the way it connects to Q4 that makes no sense?
Max.
Max.
A fully charged mains rectifier/reservoir capacitor can spark erode a decent chunk off the end of the screwdriver used to short it. In "do as I say, not as I do style" - you should use eye protection because tiny globules of molten metal fly off.So if i just short the cap out, with a wire or with a resistor?
The trace thats broken is very thin, however i will use something substantial to handle the current from the 240v motor.
I know this is some basic principles but i just wanted to double check i was safe to put the soldering iron to the copper with this capacitor on board after AC power.
You could go as low as 10R if you like. A 2.5W vitreous would be good because the glass coating insulates it from the fingers holding it.Thank you for the information Ian, was getting a little confused on what size resistor would be ideal for this situation. Low resistance, High power rating. Thanks!
Pretty much same here - unless its a seriously huge electrolytic, a 10R 2.5W should do the trick.Wattage rating is basically a rating of how hot the resistor will get under relatively constant conditions. For discharging a capacitor, you can exceed the labeled wattage rating considerably, as the time should be short. And as the capacitor voltage drops, so will the current.
John
But no one was suggesting 10R permanently across the cap in circuit - just dab it on the terminals, that's all the time it takes to discharge.I would have though 10R was low, all you have to do is connect a even a 1k- 2k and just wait a short period until the charge dissipates, often these are permanently connect across the cap in circuit.
Max.,
Minor point as most seem to have understood what you meant. But. As the esteemed @WBahn is wont to point out - units, units, units!And when calculating the wattage needed, you would use ohms law, right? So for instance i take the highest voltage it could be in the cap, so in this case 400v. Say i wanted to use a 100R resistor, 400/100 = 4A of current, so
4A * 400V = 1600 - 1.6A.
Is my working correct?
When I did servicing full time, I used to keep a light bulb with a pair of leads soldered on. It was manly used to bridge fuses that had blown violently so I could power up without further damage and take measurements.While we touched on it briefly, this time around there were a little more given information, more depth. I know feel confident in the resistor choice for a given application.
I'd still like to know how to go about doing it with a normal household lightbulb, visual indication that the cap is drained that way too.
You're right. I'm sorry. I did mean to use a = rather than a minus sign, i don't normally do that sort of thing as i'm anal about little things like this. Thank you for pointing this out to me. So it would be 1600mW which is 1.6W, is that correct now?Minor point as most seem to have understood what you meant. But. As the esteemed @WBahn is wont to point out - units, units, units!
4A * 400V is NOT equal 1600 -1.6A
You don't specify the units of 1600, but they should be Watts. Then what in the world are you trying to subtract Amps from Watts? No can do! Personally, I don't know why you are attempting to subtract anything at all.
Since it does not make sense, what if you meant the minus sign to be an equal sign. I'd argue that 1600 something (it must be Watts, because that's what the left side equates to) cannot be 1.6A. The right side of the equation could make sense if the units for 1600 were mA, BUT where did they come from?
I've gone on and on to illustrate the confusions that occur if your units are missing please don't take it too personally.
