Fixing laptop's speaker harness?
Discussion in 'General Electronics Chat' started by steep humor, Mar 6, 2016.
  1. steep humor
    Mar 6, 2016
    Hello. I don't know whether this is right place to put this question, but seriously need your help.
    While I was fixing my brother's laptop, I accidentally put the harness off which was the part of the left speaker.
    I'm considering of soldering, but there are two types of circuit.
    Is it adherable? What is the use of that green part on the board which is damaged? Please help me guys.
  2. WBahn
    Mar 31, 2012
    18,088
    4,917
    MOD NOTE: Moved from Homework Help since this is clearly NOT a homework assignment.
  3. #12
    Nov 30, 2010
    16,704
    7,354
    The lighter green part is the copper conductors showing through a green anti-corrosion coating. It looks like you ripped some of it off and it is not clear what it used to connect to...if anything. Soldering is the usual fix, not adhesive.
    steep humor likes this.
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    Use 22 to 26 gauge magnet wire to replace damaged PCB traces. Super glue the wire in one spot, wait till dry, bend and follow old path of trace with wire. Gluing it down at each place where it changes direction.
    #12 and steep humor like this.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    Kermit comes up with a good idea. If you superglue the ripped-up piece to the circuit board, you can solder it back into its previous position. You have to scrape the green coating off the touching edges so you can solder to the copper.
    Personally, I think there is enough remaining real estate to just solder-tack two wires on and run them to the speaker.
  6. steep humor
    Mar 6, 2016
    Thank you guys. I should try it!
