Fixing Burning resistor for LED
Discussion in 'Homework Help' started by parmaja, Sep 22, 2014.
Thread Status:
Not open for further replies.
  1. parmaja
    Thread Starter Active Member
    Jul 2, 2008
    37
    I am trying to fix my "LEDs with battery emergency light", charged from the main power by using X/Y Capacitor (X Rated)
    http://snag.gy/hac14.jpg
    Here is the part of circuit
    http://snag.gy/TfJYt.jpg
    The problem is the R2 for led indicator of charging, it is burning, i replaced all components except the board, but still burn, this product worked before with me for 2 years before i found it burned 2 risistor, and one transistor, name and values of components written on the board so it easy to replace the damaged ones.
    I Replaced the R2 with more higher wattage but still burn and smoking, the voltage before this resistor is about 22 volt.
    I cant find why still burn, the led replaced twice, R replace to 2k, same.
    Any idea to check what the wrong?.
    Thanks in advance, i am just a programmer fixing my tool with my self, so sorry if i put the topic here with Home work.
  2. JoeJester
    Apr 26, 2005
    3,403
    1,230
    Other than connecting directly to the mains being a topic not discussed here, I do have one question?
    Is your capacitor really 225000 farads?
    parmaja likes this.
  3. parmaja
    Jul 2, 2008
    37
    I replaced the capacitor 225k 400v with another one, same, and it give me 22v, my main power voltage is 220
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    225K = 2200000pF = 2.2μF and K is a 10% tolerance
    JoeJester and parmaja like this.
  5. parmaja
    Jul 2, 2008
    37
    Sorry it is 105K not 225 :p
    but i replaced with the same value, maybe i need to replace it again?
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    No, you don't need to do that. Try to add 220Ω/0.5W resistor in series with capacitor.
    And R2 resistor wattage is ? More than 0.25W
    parmaja likes this.
  7. parmaja
    Jul 2, 2008
    37
    I think it is more than 0.25w but idk the value, it is the blue one in the picture
    http://snag.gy/x98u7.jpg
    What the useful for adding 220Ω 0.5w if i can add one resistor for example 1.5k 0.5w, in fact i added it, and burned?.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    LEDs directly from mains is extremely hazardous, as well as against our Terms of Service. Think about using a Wall Wart.
    parmaja likes this.
Thread Status:
