Fixing an Outboard DAC
Discussion in 'General Electronics Chat' started by giro1990, Sep 12, 2013.
  1. giro1990
    Sep 9, 2013
    Hello, I'm new to this forum and I was hoping someone could say how plausible it would be to fix this (as opposed to binning it):
    basically, I plugged this into a powered USB slot and it looks like doing so fried the chip at the start of the board. It did work before I did this.
    I was going to throw it out but I paid alot for it so I might sell for spares and repairs if anyone would like to undertake such a repair and/or if that is even possible.
    Would give it away to anyone willing to fix it
    or pay for it to be repaired.
    or repair it myself, if its easy enough. I have soldering iron, might need a fine tip solder however.
    Thanks (in a rush!) will report back
    p.s. Its a HRT music streamer II
  2. giro1990
    Sep 9, 2013
    I'm assuming only the first chip was fried so I might attempt to fix that.
    as I cannot see damage anywhere else on the PCB.
    Still up for sale in meantime however (its a good dac, just broken).
  3. ErnieM
    Apr 24, 2011
    7,437
    1,626
    While it is a little buried between the USB socket and those LEDs the device is not a hard part to swap out for anyone with the right tools. I could do it in a NY minute.
    The hard part is determining just what part this is, then getting your hands on one.
    And welcome to the forums!
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's likely to be a standard linear voltage regulator.
    However fried like that seems to indicate a nasty overcurrent/overvoltage condition (or both!) has occurred, so there is possibility of any downstream electronics being fried as well (like processor or DAC chips etc).
    It's not that hard to replace the IC, but keep in mind that still only gives you a 50:50 odds of fixing it (as other parts might be blown).
