I'm fixing this PC power supply which has a bunch of swollen electrolytics on the output. I have them all replaced with new ones, and it's working good now.
I notice these bleeder resistors (or dummy loads?) on the output. Some of them, in the 5V rail, is low enough in resistance value, 20 Ohms - 2 Watts rated. Is this resistor really necessary to be in there? It's pretty hot to the touch when the power supply is on. If you can see in the picture, it's charred and has blackened the board around it. Also the capacitor near it seems to bulge more than the others.
So can I just remove all those resistors, or at least replace them with higher value ones? what value would it be? I am aware that some SPMS requires a minimum load on the output to work correctly, but this power supply is to be used on what it's intended to, a PC.
Thank you for your advice.
