With the center tap connected and the 38v/52v pair connected, I still get squarish waves AC output on the transformer (much lower Vpp) and still have good signals at the MOSFET gates. But with the center tap and the 50v/63v pair connected, the signals on the MOSFET gates are back to junk and there's no more AC on the transformer. So it must be something down stream on the 50/63V side of things. I was not able to disconnect the circuits past the diodes yet, I'll have to take the PCB out when I've got a bigger block of time so I can do that.
Aside from the power inputs, there's not much DC. Some spots have 5V relative the chassis, but not relative the power supply negative (battery -).
I really wish I could find a schematic. I'll ping Phoenix Gold to see if they'll share it. I'm not expecting them to, but there's no harm in asking. In any event, we've really narrowed it down. Next I'll take the PCB out so I can see the traces and have access to start removing things.
I wonder if this is going to turn out to be the case. What's the best way to test them?Check all your output power transistors. I have had a couple where these went bad. If so, replace them all. Common on this unit.
